Автор Тема: HF20A проволочная антенна  (Прочитано 37438 раз)
« : Августа 02, 2017, 16:00:30 »
Предлагается к повторению довольно интересная антенна.
https://www.409shop.com/409shop_product.php?id=117466#
HF20A HF 1.5-30MHz 100W WIRE antenna
     Description
Antenna description: " widely used in military , water and so on emergency communications using antenna concealment , easy to set up , no debugging , do not need tune -day , you can work the whole paragraph 1.5-30mhz ,0 -500 km without blind , the effective distance and inverted v antenna rather, in the range of 1000 kilometers effective communication . " Even for those who do not can not be set back v friend, because it can be set up in various forms , can be horizontal , inverted v, triangle , the frame line , stayed out of the window and so on. Outdoor set up, more convenient , readily detected at the roadside to 0.5 meters above the length of the antenna above the tree branches propped up on it , the location could not straighten the antenna , there is no problem , let go antenna Raowan  type can be, one minute to get the antenna erection ! ! Is installed outdoors and special environment set up radio stations is a good helper ! ! !
Recently , concerns, and I like this antenna more people, but there is a need to make a grant to a friend now ! This antenna is very easy to set up , one person one minute can be set up is good, but the antenna is not required to debug , from 1.5 mhz - 30mhz standing waves are very ideal height from the ground is also not strictly required, more than 0.5 meters above the ground can be worked , outdoor gantry I also like to use it to do qso
Parameters
1. Max power : 100w, Average power : 50w
2. Operating frequency : 0.5-30mhz,
3. Standard transducer : 20m
4. Transducer material : 1-1.5mm multi-strand copper wire
5. Stainless steel nail : Two (Bring your own)
PACKAGE CONTAIN
    1 x HF20A HF 1.5-30MHz  100W 20M antenna
    2 x 1.5M antenna
    1 x HF20A Balun (The white Box)
    1 x Special-purpose part (The golden metal part)
    1 x User Manual
Описание от соседей:
http://hf20a.toimii.fi/
Предлагаю сделать походный вариант!
5-6м удочки у нас есть и в сложенном состоянии они довольно компактные.
Тему завёл не просто так. Мой сосед Олег ES1DG долго и успешно использует такую антенну на даче и она зарекомендовала себя с положительной стороны!
Re: HF20A проволочная антенна
« Ответ #1 : Августа 02, 2017, 17:20:26 »
Эта конструкция очень сильно напоминает антенну бегущей волны,что применяли у нас вояки для разных серий Р-...
« Ответ #2 : Августа 03, 2017, 14:34:43 »
Неплохой вариант. Только наверное проще купить готовый вариант и не заморачиваться с компонентами .
« Последнее редактирование: Августа 03, 2017, 15:09:55 от ES3JM »
« Ответ #3 : Августа 04, 2017, 12:02:45 »
Можно купить готовый вариант. Не так уж и дорого.
Можно самому собрать. Где то 15-20 евро получится.
Сейчас повертел антенну в моделировщике. Не знаю как там описать штыри вбитые в землю, вместо них поставил по 4 противовеса 3 метра с каждого края. При данном раскладе антенна имеет отрицательное усиление. Она действительно очень похожа на АБВ.
Играя с высотой подвеса и точкой запитки можно получить лепесток с невысоким излучением. И опять же отрицательным усилением.
« Ответ #4 : Августа 27, 2017, 22:14:14 »
Сегодня была прекрасная погода ( могла бы и вчера такая быть, только поездку загадила блин) и решил потестировать антеннку.
Пошуметь я вышел уже после обеда, поэтому не знаю какое прохождение сегодня было на 20м. Сначала покричал на 50вт, потом на 100. Тишина. Решил погулять по диапазону. В итоге на 20м сработал с 3 станциями на 50Вт. Давали рапорт от 56 до 59.
Ближе к вечеру пошёл на 40м. Там на мой вызов подошёл Итальянец и дал 59. Больше никто не подходил :)
Полотно антенны согласно описанию, можно подвешивать как inverted v, делать треугольник, П- образно. Этим займусь на неделе в ходе экспериментов.
На 80м была устойчивая местная связь. Это увидел Андрей ES4RLH, с которым я созвонился и послушал по телефону принятый через websdr приёмник сигнал. Довольно громко проходил на 50Вт.
